Timing belt question...
Old 04-05-2010 | 08:24 AM
Sled21's Avatar
Default Timing belt question...
I just helped my son get his first car, a 2002 Accord Cp with 4 cyl auto. The engine has 102K on it. Having never owned a Honda before, I am just now learning the drivetrain. From what I hear, the timing belt needs to be replaced some time around now. Is there a warning sign that this needs replaced, or should it just be done because there's 100K on it? Also, about how much should I expect to pay for this maintenance?
Old 04-05-2010 | 10:50 AM
Sled21's Avatar
Nevermind. Called the service dept and asked them....
Old 04-05-2010 | 12:29 PM
Just to answer your question encase others feel the same way, also obviously a service department is going to want the business.
It should be replaced soon, there arent really any warning signs per say. I guess if you looked at the belt and it looked worn or a lot of rubber shavings in the timing cover. But if you already had that much off to inspect it you my as well just replace it.
It can be a rather costly job as it does take a while to do and is slightly complicated with a lot of room for error. Not something your weekend do it yourselfer really undertakes. At a Honda dealership I would expect a ridiculous price of at least $500. Could probably get it cheaper at a local shop.
Old 04-05-2010 | 08:47 PM
Sled21's Avatar
Thanks for the response. You called it pretty close, they quoted 540 for the belt, new water pump, flushing radiator, etc...parts and labor.
Old 04-05-2010 | 10:05 PM
Depending on where you're located, that might be an OK price. Lots of labor in this job, & labor rates vary A LOT.
Really no warning of a bad timing belt, except for crashing noises when the pistons hit the valves. Then it's too late.
john_pyro
08-04-2019 06:06 PM
5.0stang
04-23-2013 07:37 PM
ss485
02-23-2011 09:18 PM
Jay 3rd
02-17-2008 11:54 PM
Tony1M
04-01-2007 06:42 PM
