timing belt/seal/water pump replacement DIY?
I was reading in the Gen tech after searching a thread by Tony where it was mentioned a DIY thread. Has it been done? If not, could you do one? Mainly in the thread I would like to see how others have installed the seals in-car. I have seen the special tool that Honda has, but is there enough room? A socket with long bolt/nut/washer? Those tips would be nice in a DIY thread, besides the normal timing mark alignment, proper belt tensioning procedures, etc.
Thanks!
Thanks!
Check in the Common DIY Threads for a how to.
Here is something that might help as well
"honda-tech.com/showthread.php?t=1908944"
pimpp1184
11-05-2009 10:55 AM
mark95
05-18-2009 12:47 PM
ZMan3000
05-15-2008 04:10 PM
