Timing belt tensioner pulley
Old 01-31-2014 | 09:03 PM
For that tensioner nut, I took a socket and ground off the end a couple mm because the internal profile of most sockets is beveled on the end. That way it engages that very shallow nut a little better.
Old 02-03-2014 | 01:01 AM
Not sure's Avatar
Thanks for everyone's help. Finally got it off. Removed and installed new water pump. Got new timing and balancer shaft belts on as well as new tensioner pulleys ( with new nut ). Now to put everything else back together. Thanks again
Old 02-03-2014 | 01:02 AM
Not sure's Avatar
By the way. Username " not sure", because I really wasn't.
Old 02-17-2014 | 02:44 PM
Not sure's Avatar
Okay, now two weeks on the road. Now the water pump is starting to whine. Could it just be my belt is too tight, or need another water pump
Old 02-17-2014 | 02:50 PM
Did you use the normal tensioning procedure to loosen tensioning nut, and turn crankshaft 3 teeth on camshaft sprocket pulley, then retension nut?
Are you sure you engaged the tensioner bracket to stud on oil pump cover? If misaligned this will cause whirring noise.
https://www.hondaaccordforum.com/for...warning-22046/
Old 02-17-2014 | 04:29 PM
Not sure's Avatar
Yes I did get the rear pulley tensioner bracket on the stud correctly. I did put new tensioner pulleys on when I first did the job. The belt does not seem to be too tight. I do still need to loosen and remove the belts. Maybe I can tell more then. Thanks
  #17
Old 02-17-2014 | 04:41 PM
The timing belt isn't supposed to be TIGHT like an alternator belt. Take the long span of the belt closest to the radiator (crankshaft all the way up to camshaft). That long span should just be able to twist less than 90-degrees.
The tensioning method (turn the crankshaft a few teeth) allows that weak little spring to take up slack over on the waterpump side of the belt, but that spring isn't so strong that it makes the belt overtightened. It's tempting to take a coathanger & hook onto the bracket of the tensioner pulley, & pull it up tight.
  #18
Old 02-17-2014 | 05:06 PM
Suggest removing accessory belts and starting engine to confirm noise is from the timing belt.
Noise could be power steering, alternator, AC idler bearing, or slipping crankshaft pulley bushing.
Old 02-18-2014 | 10:49 AM
Not sure's Avatar
Ok stupid question. When I am aligning the pulleys. Can I rotate cam pulley independently or do I turn it with the belt on using the crankshaft then take belt off to align crankshaft independently? I understand that front and rear turn independently with rear at 5 o'clock and front has mark seen from top.
  #20
Old 02-18-2014 | 10:53 AM
Not sure's Avatar
Fw tdc and cylinder 1 do match up when camshaft sprocket is lined up. And crankshaft also has an arrow marking
Quick Reply: Timing belt tensioner pulley
