Timing belt/Water Pump+Balancer Shaft Seal
Old 02-10-2007 | 12:27 AM
quietgiant's Avatar
Default Timing belt/Water Pump+Balancer Shaft Seal
I'm finally ready to do the Timing belt & Water Pump replacement on my 99 Accord 4cyl V-Tec. I have the Cam & Crank seals, both tensioners, both internal belts, valve cover gasket setand the water pump but, no balancer shaft seal. I need one thing clarified, does the 99 have a balancer shaft seal? I can't seem to find one listed.
QuietGiant
Old 02-10-2007 | 12:58 AM
deserthonda's Avatar
Default RE: Timing belt/Water Pump+Balancer Shaft Seal
yes it does,,,,,,,,,,part # 91223-PTO-003 ... I would definately install a balancer shaft seal retainer as well... earlier years had a tendency to pop out . there was a recall on those \my professional advice... install it ,, cost is only about 3-5 dollars that way you can be sure that the seal will not pop out
Old 02-10-2007 | 01:02 AM
quietgiant's Avatar
Thanks... Once again you come through.
Regards, QuietGiant
Old 02-10-2007 | 01:26 AM
Welcome ......
wendellanderson2009@hotmail.com
06-22-2012 03:49 AM
BrotherAli
12-14-2011 11:27 AM
cutlass327
10-15-2011 08:07 PM
live2rice
08-12-2010 10:36 AM
