TPS Calibration using ohms
Pins 1 (sensor ground) & 3 (sensor +5) are either sides of the potentiometer resistor. Center pin 2 is the pot tap. You should have full resistance between 1 & 3 (~4.5KΩ) and variable resistance between 1 & 2. Ditto for voltage when the pot is powered.
I would get a resistance reading from 1 and 3 but not from the 2nd. I guess ill just hook it up to my car and use the voltages. It isnt difficult, I wanted to have that all done and ready for when I put it on my car.
Thanks for the help though. I now know that it is possible.
1997, 97, accord, acura, calibration, clibration, honda, recalibrate, se, specifications, supposed, tps, tsx, v6, voltage
