Traction Control Sensor
Old 09-04-2010 | 10:40 PM
H22A Accord's Avatar
Post Traction Control Sensor
hey guys i have a 97 honda accord with a H22A engine....when am driving on normal roads an press down on the gas pedal to make speed...the TCS light flashes while making the car flatter an loosing speed rapidly...no gravel or oil or anything of that sort it on the road in order to engage the TSC but once i press down to make spead it flashes an slows down the car to a complete stop if keeping yur foot right down on the gas pedalone the TSC is off...i have no problem whats so ever...thx in advance guys
Old 09-04-2010 | 11:08 PM
Do you meant the ABS light is flashing?
Old 09-04-2010 | 11:17 PM
If it is the ABS light, short the service connector under the glove box with a thin paperclip or a piece of wire. See similar instructions in link below, just count the abs code, not the check engine light. Your car will only have the two pin connector under the glove box.
When you turn the key to the II position, the ABS light will turn on for two seconds, pause for 2 seconds, then start flashing the code.
ABS codes have a main code and sub code (like 4-2). The first part of the code will flash, a one second pause, then the second part of the code will flash. There will be a 5 second pause between code(s).
dhost.info/accordinfo/howto/cel.html
Old 09-05-2010 | 03:45 AM
Thanks PAhonda but it is not the ABS light that is Flashing its is the "TCS" ligh thats flashing and making the car flatter under high rpms.... the traction Control Sensor...thats the light that is flashing.... wen it on... once i press the button to turn it off i dont have tht problem....
barticus520
10-24-2014 05:45 PM
anyt777
09-16-2013 07:16 PM
Salzar540
03-31-2011 10:11 AM
freightliner009
03-30-2010 06:25 PM
jlmartin42
11-08-2006 10:38 PM
