trailer wiring connector
Old 06-18-2014 | 01:21 PM
ProfPAS's Avatar
Default trailer wiring connector
How do I connect the trailer flat plug to the harness inside the trunk? Do I need to cut a hole?
Old 06-18-2014 | 02:29 PM
Normally, you just close the trunk over the trailer wiring. It usually doesn't harm the wiring, as there is a slight gap between the trunk lid and trunk area, which is sealed by the weatherstrip.
Old 06-18-2014 | 05:03 PM
fvansan's Avatar
Yes, that is correct and I advise you wrap some electrical tape around the cable just to just provide a little bit of extra protection.
Old 06-19-2014 | 09:31 AM
ProfPAS's Avatar
Thanks for the info. I noticed this morning on the trunk by the license plate,a rubber plug. I am going to see if it goes through and if it will also work.
Thanks again!
profpas
basket_case
05-10-2015 07:06 PM
Rider1958
05-13-2011 11:54 PM
JOwen2777
04-25-2011 10:05 AM
bozos_si
12-13-2010 09:18 PM
honda97acc
11-21-2010 02:08 PM
