Trailering a popup camper, 01 4cyl..?
Old 07-29-2011 | 06:42 AM
tnci's Avatar
Default Trailering a popup camper, 01 4cyl..?
I'm considering a "popup" type camping trailer, something with ac/heat unit. Car is an 01 4cyl auto, 156k, rust free, good condition. Would a suspension "upgrade" be beneficial, and, if so, what parts? HD shocks, stabilizer rubber? Understand trans fluid will need frequent c/o.
Yes, the lighter the camper, the better.
Thanks for input...
tnci
Old 07-29-2011 | 10:45 AM
bigpat's Avatar
Almost A Senior Member
I would suggest that you install a transmission oil cooler and take a good look at the radiator/cooling system on the car...Those two are suspect in this situation...Front brakes as well !!
Old 07-29-2011 | 10:54 AM
moey's Avatar
I dont think accords have a towing capacity but I could be wrong. I wouldn't tow much beyond what the weight capacity in the car states in the door. Also make sure there is very little weight from the tongue on the car, like almost none.
Old 07-29-2011 | 12:33 PM
Owners manual should have towing capacity. It's not particularly large, but it isn't zero either. Maybe 1000 pounds with 100 pound tongue-weight.
soba_03
05-27-2014 05:52 PM
kenwood guy
09-15-2013 04:02 PM
PhagnaScotty
04-01-2008 11:30 PM
jasonsaccord
03-26-2008 09:52 AM
RTexasF
03-06-2005 12:59 PM
