tranny problem
tranny problem
hi i just bought a 1993 honda accord dx automatic sometimes when i put it in drive it has low power i have to shut of the engine start it back up that works sometimes but that sometimes dont work i have to disconect the battry for a while and then its fine again it actulaly shifts realy nice and smooth this happens about once a day usualy over night and after it warms up a bit any ideas what can be cousing this is my tranny going out? im also having another problem then engine light is always on and when i put on the turn signal the oil light flashes in instead of the blinker arrows would highly apreciate any advice thanks in advance
Problem may be poor electrical ground somewhere. This can cause all sorts of problems. Check all grounds under hood carefully for cleanliness and security. Check battery posts and battery connections.
Check for engine codes (see diy section for instructions) and get any engine and transmission codes.
Oil light problem could be related to loose grounds or a defective Integrated Control Unit (ICU). Both oil light and turn signal are contained in the ICU. Power for the flasher and the oil light are connected. Circuit diagrams are incomplete, so difficult to understand how your problem might arise.
First check underhood grounds carefully.
tranny problem
i checked for loose grounds i only found the ground from the battery and on the power stering pump they seemed fine is there more ground wires were are they located i couldent spot any more if its that icu you think thats whats cousing the tranny problem if it is is that hard to replace
tranny problem
yes i did short the service connector i a used a bent paper clip but when i put the ignition to on the check engine light dosent come on only when i start the car its on constantly is it ok to start the car while the service connector is shorted out
cbold681
02-28-2011 07:47 PM
