Tranny problem when cold.
Old 03-10-2011, 06:30 AM
Originally Posted by atransmission.info
This transmission has a sensor in the valve body that will cause this. drop the pan replase the sensor...... hope this helps
Well, Honda automatic transmissions don't have a pan.
Old 03-14-2011, 08:46 AM
mb28's Avatar
Well. 1 year later and I've just been dealing with it. Shortly after making my original post, the weather started to get warmer and I sort of forgot about it since it stopped.
I recently had someone suggest using Sea Foam for transmissions then changing the fluid. So I'm going to pick some up, run it for a while, then change the fluid and see what happens.
I believe the manual for my car says it takes DEXRON II, but good luck finding that.
Old 04-23-2011, 05:34 AM
Default "I recently had someone suggest using Sea Foam for transmissions then changing the fl
Let me know if the foam from the Sea helps ,,,, Been hearing a lot about it... I thought it may be worth a shot,. Thanks!
Old 04-24-2011, 07:12 AM
phastlt1's Avatar
It's been nearly 2 months, and the transmission has been working well with the drain 3qts, add 3qts method. I have done this 2x with the last being nearly 2 months ago. On occasion, there is a hint of slippage, but for the most part problem solved. It's amazing what the correct fluid will do for your honda.
d0n
12-10-2014 07:42 AM
Clevor
11-27-2013 03:08 PM
wings
01-13-2012 11:31 AM
spoconn
08-21-2009 07:06 AM
tranwreck
04-30-2009 09:27 AM
Quick Reply: Tranny problem when cold.
