Transmission or Clutch gone bad ?
Old 08-24-2011 | 06:41 PM
D-ODD-1's Avatar
Hope thats just the issue. Cause i called my friend that i bought the car off and he said he got it off fleabay !!!! OMEN
Tek310's Avatar
drop the trans and tell us what you see.
inspect the clutch disc, fork, and throw out bearing.
being your clutch may have been ran all the way down, your flywheel could be glazed from slippaged and will need to be resurfaced
Old 08-24-2011 | 07:00 PM
D-ODD-1's Avatar
Will do that sat and post pics of my findings ....
Old 08-25-2011 | 04:31 AM
D-ODD-1's Avatar
What transmission fluid i use ? On my Integra i used synchromesh since i was told its the best for those transmission.
Old 08-25-2011 | 08:54 AM
If the clutch was worn out, the speedometer would NOT indicate.
This sounds like one or both axles have popped out of their sockets in the transmission.
Or (worse) the differential is broken. But I guess that would make nasty noises.
Old 08-25-2011 | 09:16 AM
D-ODD-1's Avatar
once it gets better outside i will post a little vid to show u guys.
  #17
Old 08-26-2011 | 10:00 PM
D-ODD-1's Avatar
Okay so today i did a little more diggin and it was the axle that popped and my master cylinder is leaking so found most of the issues with car hope thats it lol
  #18
Old 08-27-2011 | 10:06 AM
Tek310's Avatar
jim i thought that my self as well.
axle popping out was one of my original probable causes.
glad you found it. your mounts must really be messed up if your axles popped out.
our cv axles just pop into a socket and is held in place by the axle bolt on your wheels.
if your transmission is misaligned it will pop the inner cv joint out.
  #19
Old 09-01-2011 | 09:42 AM
D-ODD-1's Avatar
Well the axle looks like it never had the pin so i just went out and bought a new axle
giulio76
12-29-2012 12:16 PM
maq1982
12-19-2008 03:14 AM
powerpeecee
06-06-2008 08:17 PM
gkt
04-10-2008 08:06 PM
munishf
05-14-2007 03:07 PM
