Transmission Locked in Park, Brake Lights out
Old 10-16-2007, 09:02 AM
falkore24's Avatar
Default RE: Transmission Locked in Park, Brake Lights out
The speed was his estimate from where the tach was. Too fast to actually look at the speedo. I'll post the story in a bit.
  #22
Old 10-16-2007, 12:57 PM
RR_Rex's Avatar
This is the switch correct?
This is the connector
i dont see where im supposed to jump two wires.
  #23
Old 10-16-2007, 02:05 PM
sir_nasty's Avatar
There should be the two wires (white/yellow and white/black) going to two of those metal connectors if you have the right plug (it looks like you do) just insert one side of the paper clip into each side of that connector so the two wires are "jumpered" or connected essentially. Bend the paper clip into a U shape and stick one prong from each side into the slot for the correct wire
  #24
Old 10-16-2007, 02:11 PM
RR_Rex's Avatar
OK, that was my confusion. I'll do that after class. Does 40 bucks for the OEM part sound right to ya'll?
  #25
Old 10-16-2007, 02:21 PM
deserthonda's Avatar
Yo nasty.........I am going to do a DIY write up on this,, i was wondering if you know how i can send these 2 pictures to the DIY write up that i am going to do,
  #26
Old 10-16-2007, 02:38 PM
RR_Rex's Avatar
thats it. buying the part later.
  #27
Old 10-18-2007, 04:12 PM
RR_Rex's Avatar
done and done as of yesterday. PITA due to scheduling/classes/other **** that wouldn't let me get it done sooner, but overall could have been worse.
  #28
Old 10-19-2007, 01:03 PM
falkore24's Avatar
Glad it worked for you. DH, good stuff ..... one more article to direct people to!
rudeg
12-31-2015 07:23 PM
Dr. Drivability
03-20-2014 09:48 AM
crimedog76
01-04-2012 06:45 PM
campervan12000
06-15-2011 07:23 AM
lakerat
12-16-2010 08:17 AM
Quick Reply: Transmission Locked in Park, Brake Lights out
