Transmission noise
Transmission noise
2015 Honda Accord ex-L v6 coupe 14,000 miles
I just noticed the the other day, when I shift into drive, after a few feet of taking off, the transmission sometimes makes one click. It doesnt happen all the time and it is sometimes louder than others. The transmission operates fine other than the initial click upon taking off out of park. There is never any other noises from the transmission and the transmission operates normal. The click only happens after the initial take off after shifting it out of park.
After some research, I found other posts of people hearing the same noise. The other posts says the noise is the famous Honda automatic transmission click, but nowhere can I find the cause or the reason for the noise.
Any ideas
Any ideas
Because the noise happens when I am already moving forward. A brake or caliper noise whould happen when the car is first starting off or changing direction. The noise happens a few feet, maybe 5 or 10 feet after motion is started. And as I mentioned. It only happens once and not all the time
