Transmission Problem
Old 05-02-2006 | 04:02 PM
JimMurray
Default Transmission Problem
I have a '92 Honda Accord EX w/ auto trans. Recently it appears that the transmission stays in D4 at all times. By that, I mean it has little acceleration from a stop. As soon as you turn the key on, the box around D4 is lit up, as is the one around park. If you manually shift between gears, the little light box follows, but the one around D4 stays lit. Also, when you try to shift out of park, you do not have to apply the brake to get past the lock.
Any suggestions on where to start looking??
Thanks!
Jim
Old 05-02-2006 | 04:40 PM
sir_nasty's Avatar
Default RE: Transmission Problem
Welcome to the forum!
This may sound strange but do your brake lights work? There is a brake switch sensor that is activated when you depress the brake thus allowing you to shift. Is there any other lights on/anything else not working?
Old 05-03-2006 | 05:56 PM
JimMurray
Turns out it was water induced from what i can tell. Sunday I had driven thru a major downpour. Once the car sat out in the hot sun all day, it started working normally. I guess i got water in a connector somewhere.
Old 05-03-2006 | 06:09 PM
sir_nasty's Avatar
that's crazy.... glad you got it fixed! So everything just went back to normall after sitting for a while? you didn't have to do anything?
Old 05-04-2006 | 11:55 AM
mamarotta's Avatar
blame it on the rain yea yea...
trouble
08-21-2012 08:46 PM
MessAround
08-13-2011 10:45 AM
mamarotta
11-13-2010 12:10 PM
kellysa111
05-01-2009 09:35 AM
Krashnpa
01-15-2006 01:57 PM
