Transmission problem????
Old 06-01-2007 | 02:45 AM
Dairus's Avatar
Default Transmission problem????
Guys,
Greetings I have an Honda Accord automatic transmission Ex 98. The problem that Im having is that when I try to switch from Parking to Reverse neutral or Drive it won't let me it stay stuck. I really don't know why is it doing it. most of the times I got to remove those 2 screw beside and sometimes doesn't do nothing just to keep fighting till I get her to the shift desire. I will really appreciate any help cuz every time if I wish to go out or anywhere the sameproblem.
Many Thanks
Old 06-01-2007 | 06:57 AM
Chiovnidca's Avatar
Default RE: Transmission problem????
It gets stuck in park? Do your brake lights work when it's doing that?
Old 06-01-2007 | 02:18 PM
Dairus's Avatar
Hi,
I was checking my brake lights and I saw that the upper one wasn't working. Do you mean cuz of the fuse light Im having that problem???
Thanks
Old 06-01-2007 | 11:58 PM
Dairus's Avatar
Hello
I replace the light bulb and seems to work now.
Thank you
Old 06-02-2007 | 07:15 AM
Chiovnidca's Avatar
ORIGINAL: Dairus
Hello
Thank you
LOL, the bulb wasn't your problem.
Old 06-02-2007 | 11:10 AM
You may still have a flaky switch on the brake pedal. The bulb shouldn't matter.
The switch on the brake pedal does BOTH - switches the brake lights, and tells the shifter interlock that you're stepping on the brake pedal.
trouble
08-21-2012 08:46 PM
MessAround
08-13-2011 10:45 AM
mamarotta
11-13-2010 12:10 PM
kellysa111
05-01-2009 09:35 AM
Krashnpa
01-15-2006 01:57 PM
