Transmission Question
Old 12-27-2007 | 07:13 PM
kevinlurks's Avatar
Default Transmission Question
I pulled the P1738 code from my car, after some research I found that it's the code for the second clutch pressure switch. I'm on my second transmission on this car and shifting from 1st to 2nd is a little iffy. Is this a minor problem maybe even a diy or am I screwed.
Old 12-27-2007 | 10:02 PM
HondatechAV6's Avatar
Default RE: Transmission Question
it's very very simple.it's a switcheasily replaceable. it just unscrews.go to the dealer and tell them you need the 2nd clutch pressure switch on the transmission. unscrew the old one, screw in the new one. plug it in, clear the dtc, and ride away!
if you need pictures and stuff let me know. in the mean time, pick up that switch!
Old 12-28-2007 | 09:08 AM
kevinlurks's Avatar
Thank you HondatechAV6, I will pick up that switch asap. Pictures would be greatly appreciated. I tried looking for it in my Hayne's manual, but all I found was a wiring diagram that was very vauge. I also searche online and couldn't find much. Once again thank you HondtechAV6!
Old 12-29-2007 | 01:26 PM
sorry for the delay. i recently picked up an xbox 360 elite with call of duty 4...enough said.
Old 12-29-2007 | 03:30 PM
kevinlurks's Avatar
Thank you so much HondatechAV6, I don't blame you for the 360......it's pretty addictive!
Old 12-29-2007 | 09:32 PM
YeuEmMaiMai's Avatar
when you pull that switch out, inspect it to make sure that metal debris did not cause the failure
MessAround
08-13-2011 10:45 AM
genecrazy
11-08-2006 03:29 PM
Aurmon
09-18-2006 06:26 PM
F23AccordLX
11-15-2005 08:33 PM
HONDA90
11-02-2005 06:57 PM
