Transmission rebuild. Do you REALLY need to reinstall a new filter?
The Honda bond arrived today. After re-installing the engine, and new tranny I went to the mail box, and there was.............lol, lol, lol, ..............sorry I can't stop........lol, lol. After working so hard up to a point ones humor seems to reassert itself at times like these.
One more thing, and thanks for all of the advice, what kind of cheap transmission fluid can I use just to run through the system to flush out any debris left over from the rebuild?
I know from experience to use real Honda fluid for when I get the car on the road, but I don't want to waste the $$$$ Honda fluid just on a little clean up.
Thanks.
Thanks.
My advice, screw the flush, fill it with Honda ATF and drive the car.
#19
You don't need to flush out the fluid. That's what the filter is for. Oh, wait...
Buy a generic brand that says it meets the Honda specs, that is if you are going to flush it.
All that said, I'm impressed you can rebuild an auto.
#20
Update. I had to pull the transmission back out as one of the five little tubes that was in the transmission came out when joining the top case with the bottom.
This time I added a little epoxy [after sanding the end of the tube] around all of the tubes on ONE END.
That way if someone should ever have to pull the trans apart, the tubes will all stay on the front of the case [the small tube stuck in the rear of the case, then fell out when I joined the two as its kinda difficult to join them].
Anyway, it runs/shifts like it should.
Also to add the radiator cooler line did have some type of metal filter going either to, or from the radiator. It looked like an old Ford carburetor fuel filter, but its probably a Honda equivalent. I don't know if the car was recalled then the filter was added, or ???
The filter was factory as the brackets were made onto the radiator.
1TruBlu4U
10-05-2013 03:24 AM
thunder_x
10-06-2006 07:10 PM
