Tremendous drop in fuel consumption
Old 08-26-2014 | 06:42 AM
darkgreen18290's Avatar
Default Tremendous drop in fuel consumption
this summer I used to get 500- 520km from every full tank (50-53 liters usually) but to my surprise my last two full tanks I only gets 425(51L) and 431(52L) With same route, gas station and driving style.
The recent maintenance done:
Change plugs (same on the old ones)
Change oil and filter (same brand)
Change air filter with simota cone filter.
I’m wondering what went wrong to loss more or less 80km in one full tank.
There is no CEL , no dragging brakes, tire air pressure are within specs.
Yesterday I put the stock air intake back, guessing this is the cause, but is the warmer air vs colder air will affect that much in fuel consumption?
Would love to hear your thought and expertise
Thank you
Old 08-26-2014 | 08:28 AM
shipo's Avatar
While cone filters are crap when it comes to filtering, they won't affect fuel economy one way or another. Typically when fuel economy takes a dramatic plunge I recommend replacing the upstream O2 sensor (they often get lazy but don't throw any OBD-II codes).
Old 08-26-2014 | 05:10 PM
Roader's Avatar
No reflection on your car problem but I just have to point this out:
Gasoline prices in the United Arab Emirates are the sixth cheapest in the world. This was revealed by new data collected by Bloomberg. According to it, petrol in the UAE is five times cheaper compared to petrol in Norway, where prices are the highest in the world. Bloomberg has estimated that the price of a gallon of gasoline in the United Arab Emirates is offered for $1.77 on the average.
Dubai Chronicle | 4 Jun '14
It would be really nice to pay $1.77 for gasoline again.
Old 08-26-2014 | 05:45 PM
If you have access to an obd2 scanner that can provide Long Term Fuel Trim, this may provide a clue to the problem. An intake air leak can cause ECM to compensate with Long Term Fuel Trim to maintain fuel/air mix.
Old 08-27-2014 | 12:37 AM
the kind of accord i have here dont have upstream 02 sensor only downstream.
Old 08-27-2014 | 12:53 AM
Thanks texas!
i don't have obd2 scanner
i've return the old plugs and she is back to the stock air duct
full tank this morning, so far so good only noticed the silence, no broooom when i accelerate
will see what happen, will report back the result....
Old 09-04-2014 | 12:58 AM
485km for 51L, she's back, but i think this still not good.
i could say i'm driving 50/50 city hway.
what could be the other sign that i have a bad 02 sensor, i dont have CEL btw
Old 09-05-2014 | 10:40 AM
Determining a lazy O2 sensor requires oscilloscope or advanced Obd2 scanner. It's generally cheaper to simply replace the O2 sensor (<$100) and see if improvement occurs. If you have over 100K on O2 sensor, this is a good option.
Old 09-08-2014 | 05:18 AM
will try to buy and replace the o2 sensor, do you recommend any brand?
the recent full tank with 90% hway she got 320km half tank.
Is this number right for my accord?
Old 09-08-2014 | 07:24 AM
shipo's Avatar
A couple of comments:
  • There seems to be a general consensus that Bosch O2 sensors don't often work well in Hondas, use Denso sensors instead.
  • A metric of 320KM for a "half tank" doesn't really mean anything because fuel gauges are really not linear. The best way to calculate fuel economy is to fill the tank until the pump clicks off, don't "milk" it, drive until the tank is nearly empty and then fill it again. Then you have a given number of liters and a given number of kilometers which you can then use to calculate your fuel economy.
Eugene Eliseev
01-11-2013 10:26 PM
osaio
12-20-2010 09:33 AM
darkgreen18290
10-20-2010 03:22 AM
sssexy70
02-10-2007 06:43 AM
pascha
01-30-2007 04:58 PM
