Turn Signal Stalk Broken
OK, my first real post;
The turn signal stalk on my 97 Accord has cracked through the outer plastic sleeve. What type glue will work best, a polystyrene (modelers) glue, super glue, or just live with it? I have no idea what kind of plastic it uses, and don't want to gunk it up with the wrong kind.
RE: Turn Signal Stalk Broken
Sorry, thought I was being clear! Since I don't have a digital camera, here's a better description:
On the left side of the steering column is the turn signal/headlight control "stalk" (the right side one controls the wipers). Since it controls the turn signals, twists for the headlights and pulls for the bright/dim controls, it gets a lot of use. Mine has cracked but not broken off. It is still functioning, but the outer sleeve is cracked all the way through, so if I can glue the exterior, I can avoid breaking the rest of the control stalk.
Just trying to get the 2nd 100k miles out of this dependable little car!
