Under hood insulation-good or bad??
Old 06-24-2011 | 08:11 PM
dunkinidaho's Avatar
Default Under hood insulation-good or bad??
I've installed 3/4 in of foil backed foam insulation under my hood. The temp guage does not indicated over heating however when I pop the hood after a drive the engine seems very hot. Should the insulation be removed? I installed it in the first place to reduce noise but it wouldn't be worth frying the engine for.
Brian in Mich.
Old 06-24-2011 | 08:49 PM
What accord are we talking about here? Put that info in your signature, so we don't have to ask.
If the temp gauge is not going up, you should be ok.
I think that the EX accord had sound deadening pad to reduce noise (depending on the year). I am not sure if it acts as an insulator. That should depend on the material used.
My TSX has this feature as well.
Old 06-25-2011 | 06:05 PM
thanks, that's kinda what I thought. I wanted to run it by some others for opinions
Brian
88 Accord Hatchback
giulio76
12-29-2012 12:16 PM
RobinsonRicer
08-01-2012 04:34 PM
sacrider
07-30-2011 06:24 PM
ad00a973
05-03-2009 10:36 AM
