unknown vaccume leak
Its not the egr silinoid. I replaced that before. It run the other way around the intake and then has a 3way split in it. One goes to a black box right behind the pass headlight and the other 2 go to a silinoid/box looking thing i think between the air filter box and motor Its hard to see its right under the intake. But it helped my power issue out alot and it idles steadier now but im worried what i unplugged if its gonna mess any thing up or if it needs replaced Im gonna take some pics this weekend. Should i message you them or post them here?
Post the pic's here as I and several other members have or have had this "car". I'm still a bit "fuzzy" as to which hose you are talking about but a pic.....I'd either know it or be happy to go outside pop the hood and understand what we are talking about.
Compared to mine, yours is a baby.....over 376K on mine Still OE trans and engine...knocks on wood.
I cant figure out how up post pics. I use my phone to post but i try to attach files and it wont bring up the thing to select a file. I traced the line back more and it goes to a filter looking box also that is attached to the intake. It has a throttle opening thing inside it. Its like a intake that goes into my actual intake if that sounds right . Also any ideas how to post pics from my phone would be helpful
#17
Go to the "Common DIY Threads" sticky post at the top of this section, you can download a manual for this car- get the one for the 94 Accord-it is the same as your 95. That is the IAR (Intake Air Resonator) system......section 11 page 6.
Most would not worry...infact you have to delete it if you ever added a hot air intake system/filter.
xaznxeclipsex
09-10-2007 02:17 PM
pturnbul
05-03-2007 02:30 PM
