Valve adjustment on 2006 4cyl Accord
Old 04-14-2006 | 03:18 AM
mpanelli's Avatar
Default Valve adjustment on 2006 4cyl Accord
I own a 2006 4cyl Accord. I was reading some of the service minder info on the Honda site and it keeps refering to "adjusting the valves if noisy" This is my first Honda and was wondering if adjusting the valves is a routine maintenance. If so how often and is it something I can do myself.
Old 04-14-2006 | 06:04 AM
marbro's Avatar
Default RE: Valve adjustment on 2006 4cyl Accord
A little of both. Its routine maintenance as well as something you can do. All you need is a feeler gauge, a socket wrench for the valve cover, another socket wrench for the rocker lock nut (box end wrench will help a little), flat head screw driver, knowledge of the clearance for intake and exhaust valves. dont know the wrench sizes needed off hand, and i know the clearance for 98 to 02, it could be different on an 06 but im not sure.
and 30000 miles if necessary, basically if you hear the valves clicking louder then normal.
Old 04-14-2006 | 07:59 AM
lightshow's Avatar
it is definately something you want to do at least every 30000, and i would not recommend doing it yourself. but i bet at a lot of shops, they really couldnt be trusted to do a better job than you.
Old 04-14-2006 | 02:23 PM
mpanelli's Avatar
I am pretty comfortable around cars. I have adjusted valves on VW's many times but my last several cars had hydrolic lifters. This is my first Honda and was not sure if they needed routiine adjustment.
Old 04-15-2006 | 03:11 PM
RTexasF's Avatar
Super Member
ORIGINAL: mpanelli
Supposedly they should not need adjustment unless they get noisy. However, a Honda Master Tech I know adjusts his every 30K as lightshow mentioned.
They haven't been out of adjustment yet but he feels it's better to be safe than sorry.
Old 04-15-2006 | 03:43 PM
deserthonda's Avatar
ORIGINAL: RTexasF
ORIGINAL: mpanelli
yo rtex are you talking about me ?
Old 04-16-2006 | 11:07 AM
RTexasF's Avatar
Super Member
HaHa! No I wasn't. Are you a Honda Master Tech?
Old 04-16-2006 | 04:29 PM
ORIGINAL: RTexasF
Ok a little history about my background.........
started working on Hondas in 1980.... worked in dealership in Wisconsin for 8 years. moved to AZ worked at dealership for 8 years ,,Opened up my own shop 10 years ago, still going strong,, we specialize on Hondas and acuras
Qualifications ...
26 years experience
ASE master tech,
Honda master tech
Honda Top Tech..
Old 04-16-2006 | 04:35 PM
lightshow's Avatar
wheres your shop at desert?
Old 04-16-2006 | 05:03 PM
ORIGINAL: lightshow
Tucson.. North/West side of town
