Valve adjustment on 2006 4cyl Accord
RE: Valve adjustment on 2006 4cyl Accord
ORIGINAL: deserthonda
Ok a little history about my background.........
started working on Hondas in 1980.... worked in dealership in Wisconsin for 8 years. moved to AZ worked at dealership for 8 years ,,Opened up my own shop 10 years ago, still going strong,, we specialize on Hondas and acuras
Qualifications ...
26 years experience
ASE master tech,
Honda master tech
Honda Top Tech..
ORIGINAL: RTexasF
HaHa! No I wasn't. Are you a Honda Master Tech?
Qualifications ...
26 years experience
ASE master tech,
Honda master tech
Honda Top Tech..
[sm=groupwave.gif] YOU are the man!!
The master tech at the shop I work at asked about this when he went to Honda school and was told that the 03+ I4 Accords only get it if they are noisy. He was told that the K series has roller rockers and rarely need adjustment. I have 67k on my 03 I4 and they still are not making any noise. One catch is that the injectors on the 03+ are very noisy so make sure you don't confuse the noise as the valves.
what about my 94 EX SOHC Vtec, does the 30k rule apply? Is this something I could do myself? Never tried it on a honda before but I've done it on Pinto's/Mustang II's... Pretty much the same?
what is the valve lash supposed to be at for a 94 accord ex? is intake ..10 mm exh .012 mm correct? and just to make sure I understand for my vehicle, at TDC I'm on #1, Counterclockwise 90 is #3, 90 more to #4, then 90 more to #2? is that correct?
go-nogo gauges... and I thought those were only for a .50 Cal headspace and timing adjustment in the military... *L*
#18
ORIGINAL: sir_nasty
