Valve Cover Gasket
Valve Cover Gasket
I have oil leaking out from between the valve cover and the head, so I'm assuming thats the valve cover gasket; It's not leaking a substantial amount, only when ran at extremes, which is most everyday.
Also, the top radiator hose, where it meets the metal receiving peice meets the engine has a gooey substance leaking out; it looks like oil but its really thick. I'm wondering about this one because i wouldnt think oil in my water system was a good thing.
I am wanting to know about these two items and exactly how dangerous each can become, so i can buy new gaskets and fix the problem.
Thanks
Thanks
RE: Valve Cover Gasket
ORIGINAL: PIGGEBANK
Thanks
Thanks
the other leak could be coolant ,, could be a bad hose , loose clamp. or bad seal at top rad hose bracket where it meets the head ,, pressure thest the cooling system. and see if leak appears ,, it will give you a better idea
thunder_x
07-09-2007 11:57 AM
