Ventin bout brake job...
Old 12-23-2010 | 04:30 PM
barticus520's Avatar
Default Ventin bout brake job...
Well I woke up happy this morning. Went outside and it was sunny but cold, still good to change my rotors and brake pads(they were in real need to be changed.) Well I get 1 tire off and here is the hard part, Im goin to kill the guy that thought of puttin those gay screws on the rotors to hold them on. No matter what I tried they wouldnt come loose, even with a impact driver... ended up strippin all of them each time till i get to the last one and the driver head snapped. I had to drill out the wide head of the screws and then use an easy out to remove the rest(they came out easy once the head was taken off.) The best part... it started snowing after I removed the first rotor so I only ended up doin the front rotors and pads instead of all around.
Again the person that thought those screws were a good idea, HE DESERVES TO DIE
MessAround
06-12-2013 09:47 AM
chenghng
12-06-2006 08:18 PM
Adie
09-12-2006 07:12 AM
MATCHU
07-06-2006 07:06 PM
Esko
11-26-2005 06:04 AM
