Verified repair - Won't shift from park, brake lights inop
2003-2007 (other years may apply as well) Shifter won't move from park (shift interlock will not release when brake pedal is depressed) and brake lamps won't illuminate. Brake switch tested good, but was intermittent in the vehicle. Replaced brake switch with Honda part (8 bucks) and problem is solved. Keywords: brake lamps lights shifter park interlock switch stuck out
rudeg
12-31-2015 08:23 PM
coat6
06-13-2015 11:08 AM
