Viberation at Idle
Viberation at Idle
My 03 Accord 4cyl is as smooth as silk...except... when I come to an idle. This is worse when the A/C is running. The car runs great other than this. I haven't had the car long and will soon be doing a mileage test to see that gas mileage is reasonable. Just didn't know it this viberation is inherent with the 4 cyl so not to worry or might signal something to be corrected.
Thanks
Thanks
RE: Viberation at Idle
if less than 36,000 miles take it to a Honda dealer you are still under warranty,, if out of warranty, chk the motor mounts, try raising the idle up a bit to 750-800 rpm..
Car been in any accidents at all ??
2003 Honda Accord
Bulletin #: 04024
Sequence #: 10008712
Date: 05/04/2004
Component Name: 061000 engine and engine cooling:engine
Make: Honda
Model: Accord
Year: 2003
Summary: Engine vibrates while idling in gear. *mj
like Rtex says call dealer ,and inquire if they can fix your car free of charge
Bulletin #: 04024
Date: 05/04/2004
Make: Honda
Model: Accord
Year: 2003
HatchJunki
03-09-2013 09:23 AM
90pioneer
04-09-2012 10:06 PM
fperezal
06-14-2006 06:03 AM
