Vibration on Acceleration
Old 03-26-2012 | 05:52 PM
zoid_99's Avatar
Default Vibration on Acceleration
My 2003 Accord EX with manual transmission just developed a vibration only when the car is accelerating. The vibration is not in the steering wheel but rather it feels like it's the whole car shaking. It only happens when I accelerate through 30mph-35mph and again when I accelerate from 60mph-65mph. It only happens or rather it's much more "pronounced" when I aggressively accelerate. I can hardly feel it when I slowly accelerate through those speeds. Since the steering wheel doesn't shake I don't think it is balance. I'm thinking axel? What's the best way to diag this?
Thanks!
Chris
Old 03-26-2012 | 06:04 PM
UhOh's Avatar
I'd note down what gears you're in, maybe rpms too, and if that makes a difference.
years ago had nissan sedan that developed vibration at ~40 and 65 mph @ 6,000 miles new.
dealer determined it was a defective tranny bearing and fixed under new car warranty.
luck
Old 03-27-2012 | 07:31 PM
zoid_99's Avatar
luck
It's doesn't seem to be gear specific which is a good thing I think. I do seem to feel a little sway in the front but I may be hyper sensitive now. Looks like it's tame to take her to the shop.
Old 03-27-2012 | 08:08 PM
I had a long running problem w/ vibration/shuddering under acceleration that was only fixed after I replaced both front axles (Autozone) w/ new Raxles. Problem fixed,...finally. Search "raxles" for my post on the problem.
Difficult to defintively diagnose w/o replacing an axle. The axles did not exhibit particular looseness when I checked them in place. R axle was beginning just recently to pop a bit, but this problem had been going on close to 2 yrs before resolved.
Old 03-27-2012 | 09:49 PM
EXV6NIGHTHAWK's Avatar
I would agree with the axle idea.
Old 05-02-2012 | 12:31 AM
zoid_99's Avatar
Best I can tell the axles are not loose. From all of my reading and observations I do believe it is an axle problem. Now the question is.. Do I do it myself or take it to a shop. My skill level is "Brake Pads/Starter". Is this something I should attempt? *grin*
Old 05-02-2012 | 01:02 AM
Search for v=jydxpsh13WQ on YouTube for a good video on how to do this. Then you can decide if you can do the repair.
Old 05-02-2012 | 10:17 AM
Dr. Drivability's Avatar
Had the same thing on my 03, both axles solved the problem, in addition the CV boots were still intact...unusual for axle to fail with boots intact, but I guess it happens. Not too difficult of a job to do, unless the axles are frozen in the hubs...happens sometimes.
Old 05-09-2012 | 10:44 AM
zoid_99's Avatar
Did you use OEM axles? If so do you mind me asking where you purchased them?
Old 05-09-2012 | 11:19 AM
nope, new aftermarket from O'reilly's autoparts.
