vibration from exhaust
Old 10-01-2009 | 08:39 PM
sicknhcky91
Default vibration from exhaust
I have a 97 accord with a cat back flowmaster setup. I recently replaced a busted motor mount in the front and now when i am slowing down i get a harmonic vibration coming from the cat and midpipe area around 1750 rpm. it only occurs at 1750 rpm give or take. It does not matter if the pipes are hot or cold b/c i know when pipes are cold they seem to sound tin cannish.
I have bent the heat shield off the pipes and hangers so there is no contact between the two. The cats heat shield is rusted but there is no sign of rattling.
Does anyone have any idea about this?
Is it woren out gaskets between the cat and midpipe or could it be something in the manifold. Any suggestions are helpful.
Thank you
Old 10-01-2009 | 10:24 PM
hondadude's Avatar
This is the first thing that comes to mind;
Old 10-06-2009 | 07:47 AM
sicknhcky91
if this was the problem wouldn't I have an exhaust leak though from woren out gaskets?
Old 10-06-2009 | 09:04 AM
mcnoople's Avatar
no they don't leak they just buzz
Old 10-06-2009 | 05:49 PM
sicknhcky91
is there any indicator on the gasket to tell that it is bad? Or is it just a replace it and the buzz goes away
deadaccord92
11-17-2010 11:05 PM
mcjewel
03-10-2009 02:33 PM
JW
02-28-2007 10:41 PM
Markus26
04-17-2006 11:30 PM
janicesaccord
03-04-2006 09:18 PM
