VSA/brake/Abs light on 2008 EX V6 3.5
HEllo guys,
So, my honda accord 2008 3.5 v6 sometimes lights going up (VSA/ABS/BRAKE) ,but if i turning off the engine and start,de lights turning down.
I passed the PDL scanner ,show me this codes :
Fail solenoid 121-21 and 121-01
Anyone Have ideia for de fix it ?
att,
Honda accord 2008 V6 3.5 with 80.000 miles
att,
Your codes are for a solenoid valve issue that is part of the vsa module. Looks like Honda sells the entire module and is very expensive. You could always get a used part for less money.
Depending on your skill level, you may be able to replace the solenoid valve on the module, or see if the issue is something simple.
Try this... https://www.myairbags.com/product-ca...n/abs-modules/
I sent my ABS ( General Motors Car) here. Got it back in 1 week. I don't see 2008 Honda Accord, but you can call them and see if they will repair it.
Note, on my GM car, I could remove the module only (not the whole ABS unit) and sent it in. They sent back the same unit to me and I put it back on. Been good for 2 years now.
My choice was something like
1) -$500 for the Module part from the dealer,
2) -$1200 for the dealer to get the ABS and put it in
3) - I take the module off and send it to MyAirbags.com for something like $150 (shipping included).
Took me about 1 hour to take it off and 1 hour to install.
Solved.
Hy guys,i solved this problem in Brazil.
Let me speak in portuguese.
O problema ocorre em todos os accords (parece ser um problema crônico),um capacitor que envia os pulsos para controlar e acionar os airbags abre com o tempo,após a troca,o mesmo voltou a operar sem erros no scanner.
Eu gastei 600 reais,em torno de 150 dollares.
English... I beg of u cuz I don’t know portages
I don’t know how to read Portuguese
according to google-translate...
The problem occurs in all accords (it seems to be a chronic problem), a capacitor that sends the pulses to control and trigger the airbags opens over time, after replacement, it went back to operating without errors in the scanner.
I spent 600 reais, around 150 dollars.
