VSS removal and install
Old 10-22-2009, 11:03 PM
94accordexgold's Avatar
i cleaned the wires and everything. Still doesn't work. How do i go about getting at and removing the VSS? I'm still not quite sure where exactly this thing is even located. I know where the actual throttle is. Is this the throttle body? Also what does this VSS even look like? i'm really at a loss here. is it easy/hard to remove/install?
Old 10-22-2009, 11:20 PM
If you cleaned the connector to the VSS, then you should have found the VSS. It is held in by three bolts and is bolted to the transmission.
Go to the DIY section and open the spooner tuner link I posted. You can download a 94 shop manual as a pdf. It will have descriptive pictures and instructions that will help you out immensely.
Old 10-23-2009, 09:02 AM
awesome i'll check it out thanks
Old 10-23-2009, 11:13 AM
i am in a real bind so i really have no choice but to go to autozone. that being said, i gave them the year make and model of my car... 1994 honda accord ex automatic 2dr coupe and they come up with 3 different VSS parts. I do not know which one to choose and i am still having trouble locating the VSS on my car. I see the throttle and i follow it down, but i can't quite make out what or where the VSS is located.
here is the link to the VSS parts list on autozone.com
http://www.autozone.com/autozone/cat...uestid=3430338
would anyone be able to tell me which one i need to get? or at least try and search on there to which part i need.
Old 10-23-2009, 11:19 AM
here is the one i found on pepboys..
http://c2c.activant.com/ctoc/index.j...ZAXhoVD1cBUz0A
i really don't know what I'm doing
Old 10-23-2009, 02:40 PM
The VSS looks like the one from Pep Boys.
  #17
Old 10-24-2009, 07:59 AM
ok... and that's located on the throttle body correct, connected to the trans?
  #18
Old 10-26-2009, 07:53 AM
No, it's not ON the throttle body. I said it's below the throttlebody, but I meant down on the transmission about 12" below the TB. Even though you've got an automatic, the VSS is located in roughly the same location as the one on the manual tranny drawing I put in earlier in the thread.
  #19
Old 10-26-2009, 09:08 AM
00AccordLX5spd's Avatar
Registered User
It's "E6" in the picture.
It's way down below the throttle body. You will need long extensions on a socket to get to it. It should be in the same place as mine in my DIY VSS replacement thread:
https://www.hondaaccordforum.com/for...ad.php?t=26761
  #20
Old 10-27-2009, 05:13 PM
perfect im going to get the part today! thanks! also quick question... what kind of bulb do i need to get to replace the light that illuminates the instrument cluster?
loadder
03-03-2011 08:52 PM
Mstrmonkyman
03-27-2010 07:10 PM
wrlips
06-22-2009 08:59 PM
ukbuckstop
05-02-2007 08:56 PM
comptoncarl
02-08-2007 03:04 PM
Quick Reply: VSS removal and install
