vtec solenoid p1259 code
I had p1259 code and car would start missing at 3500rpm. Replaced solenoid from dealer and runs great now. The check engine light will not go away though. Tried unhooking battery didnt work tried restting with code reader and no luck said cant reset code. Any ideas?
Moved post to correct forum. Read posting rules and don't post in DIY forum.
I believe 1259 is fault in oil pressure switch circuit; bad wire, connector, pressure switch, or ECU fault.
