Water inlet hose A replacement
I have a 2001, 4cyl, A/T, 187,000 Accord. Need to replace subject hose. The hose looks like a straight forward swap-out. Anything I need to know about replacing the lost coolant, air in the coolant system, etc, etc?
there will be a bleeder screw on the thermostat housing. crack that open and refill radiator until it pours a steady stream and no bubbles. also have the temp **** set on max heat
then run the car with the cap off until the fans kick on, this ensures all air comes out of the system.
meggimann2000exl
08-17-2011 11:53 AM
jamesejam
09-21-2009 03:37 PM
thunder_x
07-13-2007 05:20 PM
