water leak under passenger seat Accord96
Is water leaking in from around the plug or is that where water drops from above?
If from above, the evaporator case is filling w/ condensate from AC use and running over. Drain line repair or evaporator clean-out needed.
Tex, that's the left-side rear seat; looking in from the left-rear door. Water would have to run from the dashboard, cross over the center exhaust tunnel, then jump up to that place which is at a higher level then the front footwells.
Lovemy97HondaAccord
03-05-2014 07:04 PM
MysticBlueEX
02-18-2011 07:55 AM
