Water Pump Install
Just enough of what? Honda bond or grease??
Poorman meant a little bit of honda bond on the water pump, then lay in the gasket. Like a dab in the middle of each side. Do not put Hondabond (or RTV) between the gasket and the engine block, because the next person to replace the water pump will not have a good day.
If your gasket stays in the groove without any sealant and won't fall out, then don't use anything.
jrcastro
06-20-2006 09:28 PM
