weird acting speedo?
Old 12-04-2007 | 09:02 PM
mrwigglezdj's Avatar
Default weird acting speedo?
well i was on my way to work this am,. going 55mph and rpms were at 1700-1800rpm....well all of a sudden my speedo went from 55 to 85 then to 90 and then it went to 0 and it stayed there , and i didnt speed up or slow down, i get to work and say forget it rite now i gotta work, well im off work and the speedo works for about 3 minutes then does the same thing it shows im doing 45 jumps to 70 and holds then its on 0 and stays there , then it would jump a little and go back to 0....
anyone know what could be my issue
Old 12-04-2007 | 09:46 PM
HondatechAV6's Avatar
Default RE: weird acting speedo?
hit the dash above the gauge assembly while the problem is happening. if it magically springs to life, inspect the gauge connectors. if they seem ok and tight, no corrosion or burnt terminals replace the speedometer gauge or the engine gauge assembly, your choice.
Old 12-05-2007 | 01:41 AM
If the cruise control still works when the speedometer fails, then the speedometer is the problem. If the cruise doesn't work, then the VSS is the likely culprit. A bad VSS will cause the CEL to come on.
Old 12-05-2007 | 06:11 PM
well i have a video of what its doing ,. but i dont think it will help much, but now itonly works ever so often and now my cruise control doesnt work so its the vss
Old 12-05-2007 | 10:37 PM
i personaly hate ebay for buying, but after autozone told me over 100 for a new vss i figured i would check out ebay and i found a bunch of them but from the same guy and hes only asking 12.90 plus shipping so say 26.00 for a brand new one? would you trust it or say junk yard if i cant afford a new one?....driveing by rpm isnt fun lol [:'(]
Old 12-06-2007 | 07:30 PM
well, you get what you pay for. if he is saying they are brand new honda genunie parts and he has 100% feedback...
Old 12-06-2007 | 07:51 PM
nafango2's Avatar
a lot of car parts on ebay come with 30 day warranties. look for a VSS with one.
hondaisreal
11-27-2012 09:46 PM
fastfox1306
01-29-2010 02:00 PM
Island Accord
02-02-2007 04:24 PM
tbopha
05-30-2006 04:04 PM
phaders
01-05-2006 06:17 PM
