What do wheel bearings have to do with the brakes?
1990 accord ex. My brake pedal was going to the floor when I made sharp turns. I replaced the master and bled the system with no change. My mechanic looked at the car and stated that the wheel bearings were shot and that they were causing my brake issues. What do wheel bearings have to do with the brakes?
RE: What do wheel bearings have to do with the brakes?
They keep the rotors in line with the calipers.
If the bearings are bad, the rotor can lean away from the caliper piston on hard corners, allowing it to extend farther than normal.
That's my story and I'm stickin' to it. (unless someone else comes along with a better story...)
ORIGINAL: Rhoderman
