What to inspect on my car before roadtrip
So I'm taking a roadtrip in my 91 accord next thursday from LA to vegas, which is about 260 miles away in my car with 202,xxx miles. Some people are worried that my car might have problems with the trip, but two mechanics told me that my car should be fine. Im gonna inspect my car before i go to make sure everything is good, what should i keep an eye out for?
So far on my list is: Fluids, air pressure, radiator hoses, battery, brakes, and not sure what else.
As long as your maintenance items are up to date, then you should be good to go.
Replace spark plugs, dist. cap, dist. rotor, air filter, change oil if they are due. Check coolant level.
Check tire pressure. Make sure that your spare tire has proper pressure if you get a flat on the way.
Fix-A-Flat does not fixes a blowout, only small leaks. Do you have a full size spare to throw in? That's what I brought with me to Florida, otherwise you have to find the nearest repair shop because you can't ride a spare forever (or above 55 mph)
jrcastro
06-25-2006 12:03 PM
