wheel bearings
wheel bearings
i bought my accord not moving.
front driver wheel bearing was shot. lower ball joint was loose.
fixed that.
than i found a loose pass side upper ball joint. not bad. fixed it
today i found a loose pass rear wheel bearing. not terrible but i will change it
it sure sounds like the clicks/pops are coming from front so i checked
everything and could not find anything bad. sway bar links are good
sway bar bushing are ok.
can 1 loose rear bearing sound like noises coming from the front?
havent changed rear bearing yet but i wonder about these noises
fixed that.
i did rotate wheel while it was jacked up. the tire rotates left/right about 10deg. i looked under car and axle is turning while i do this. the play is at the transmission case. axle turns, inner cv joint turns, slop is inside trans? is that normal?
Some play is expected in trans. Don't know how much. I was referring to play in CV jts.
Try turning a tight circle slowly in parking lot while walking along side front wheels. Popping sounds near wheel are almost certainly CV jts.
