where to find listing of bulbs used in 2000 Accord?
RE: where to find listing of bulbs used in 2000 Accord?
maybe ur looking for this
http://www.sylvania.com/ConsumerProd...de/default.htm
Yes, that is what I'm looking for. However, I see its missing one of the bulbs I'm looking for. One of the parking lights found underneath the low and high beam. Do you know what the number is for that bulb?
[IMG]local://upfiles/527/1871E658F5214F79BC98AD273924AFE4.jpg[/IMG]
sometimes the easiest thing to do is just pull the bulb out and take it in to the parts store, or look up the number in the parts store book and they should be able to tell you.... I don't know it off the top of my head
in that case no i dont know ,,,,, i didnt think there was one back there... cause if you look at this image you will see only
signal , low and high beam inserts.
http://i17.ebayimg.com/01/i/07/f9/2a/cc_1.JPG
sorry i couldn't be of much help. Good luck
those headlights look like they are aftermarket... if that's the case you may have a bulb in there that isn't stock.... so then you'll have to pull it out and go match it up manually
The headlights are aftermarket however they are basically the same as the originals - the only difference is that the bottom strip for the parking light is clear instead of amber. The wiring and everything else is the same.
Here's a picture of the back of the original headlights - there you can see the same hole where the parking light bulb goes in.
The bulb is very difficult to get out and therefore, I would prefer to locate and purchase new bulbs before I attempt to pull them out.
The problem is I don't know what kind of bulb it is.
[IMG]local://upfiles/527/1805100A300E4984BD97AAF2A0BA7189.jpg[/IMG]
msucurt
07-24-2011 02:26 AM
jbrams
05-11-2010 11:30 AM
