Where is the Fuel sending unit located on 94 accord
The fuel gauge is not accurate and never reaches "full" on my fill ups. So thinking of replacing the fuel sending unit. Where is it located? Is it hard to replace? And a rough est. of the price? Do they make aftermarket ones or is this a dealer only part? I have a 94 accord EX. Thx
RE: Where is the Fuel sending unit located on 94 accord
ORIGINAL: 00AccordLX5spd
It is located within the fuel tank. I believe you have to remove the fuel tank (not a fun job)on the 94 models to access it.
I knew that was the case on the 98-02 models. But I remember TexasHonda said he removed the entire gas tank on his 94 to change the fuel pump. Did TexasHonda waste a lot of time and effort there? or am I missing something? The sending unit is part of the fuel pump right?
is this a common failure component for 94 accords? Mine actually has the same issue but I'm usually to broke to fill up the gas tank anyway so I just live with it...
ORIGINAL: sir_nasty
regards
According to how stuff works it is a common issue I guess.... Can someone confirm for me that this 37800-SV4-A03 is the part number?
http://auto.howstuffworks.com/honda-accord5.htm
