Where the heck is the VSS on 94 Accord EX????
Old 07-21-2006 | 09:48 PM
JWW512's Avatar
Default Where the heck is the VSS on 94 Accord EX????
Hello. I've got speedometer and flashing D4 problems on my 1994 Accord EX. After researching online I found that the problem is most likely my VSS. I bought the part, have it in hand ready to install but I cant find the damn thing on the car. I have seen several diagrams on the internet like the one below but maybe I'm blind, I don't see it anywhere near my distributor. Is this diagram wrong? Can anyone help?
Old 07-22-2006 | 12:06 AM
mbo1985's Avatar
Default RE: Where the heck is the VSS on 94 Accord EX????
it's a little hard to see, but it's going to be under the intake manifold on top of the transmission (on top of where the axles go into it, not where the bell housing is). I don't know if that diagram is correct. I had to buy a long screw driver to get to it, but it's not too bad. You'll see an electrical connector going to it and you just unclip that. There will two screws holding it in, take those out, swap the sensor, and you're good to go.
Old 07-22-2006 | 10:24 PM
Find it? Look farther back & farther down. That cartoon shows it like the distributor & half the tranny is transparent, & you're looking thru to the VSS which is hidden from view.
Old 07-23-2006 | 01:04 AM
deserthonda's Avatar
read up on this,, it will help..
http://techauto.te.funpic.org/vss.php
blackex19
10-22-2007 11:41 AM
blackex19
04-09-2007 09:23 PM
comptoncarl
02-08-2007 03:04 PM
01-25-2007 02:40 AM
abelh7
05-28-2006 11:13 PM
Quick Reply: Where the heck is the VSS on 94 Accord EX????
