Where is my Lugnut Key?
I have a Honda Accord 2010.
I need to rotate my tires- can't because no one knows or has ever seen the lugnut key.
I bought my car in Seattle Washington and now I'm in Tucson Arizona.
Any ideas?
thanks
Any ideas?
thanks
Otherwise, this question would be the same as "Where's Waldo???"
If you can't find it...look again, even pull the spare tire as it might have "rolled" under it...most shops have a socket designed to remove locking lugs, just hope it fits and does not damage the rim.
EDIT: I remember the days when GM had locking hub caps.....that was fun.
See if there is small black nylon pouch near the lug wrench.
The back of the package shows that they can also put the key in the nylon pouch and attached to the lugwrench. See images.
Most shops do have sockets to remove certain wheel locks. The Honda OEM wheels locks should not be too difficult for them to remove as they are not much bigger than the original lug nut socket size of 19mm and there is still a sizable gap for a socket to fit in between the lug nut and the stock wheel.
corlyf
09-13-2012 12:30 AM
