Where should i start from stock ? help!
When you start modifying the car, you increase the chance to have problems if this accord is your daily driver.
The 96 is OBD2, so you may have to keep it OBD2. That would mean an H22A with an OBD2 PCM (the 96 prelude PCM is what you would need).
The turbo installation would be easier, but not sure what PCM you need.
You may want to consider starting with suspension and brakes before going after HP.
You haven't indicated whether you have a manual or an automatic; if you have the later then 200 is way too much power for the transmission.
It is probably far cheaper and far-far less aggravation to sell your car and buy an otherwise similar car with a manual transmission.
