White smoke from engine after Seafoam treatment
Old 11-09-2011 | 04:11 AM
mishakol129's Avatar
Default White smoke from engine after Seafoam treatment
I just used 1/3 can of Seafoam through the PVC valve of my 91 accord (320k miles), and after (or while) I did it, white smoke was coming from the engine bay. It looked at first like it was coming from the valve cover but then I saw that it was coming from below the VC... It did fix my idle problem (thank God) and it also made my car run better, but i'm kind of surprised / worried about this smoke from the engine even though it did go away.
But what could this be? Is it a bad problem? I read on another forum that its a leak coming from the flexpipe, but what think ye?
Thanks.
Misha
Old 11-09-2011 | 01:08 PM
Is the engine still putting out white smoke after you did the seafoam treatment?
Old 11-09-2011 | 01:13 PM
g22cd5's Avatar
Supper Moderator
you have a exhaust leak. The white smoke is all the carbon burning. IF it's coming from the engine bay then you must have a exhaust leak b/c the white smoke wont occur until the the sea foam burns the carbon. Check your header and down pipe to the cat and make sure your exhaust is not broken or any of the flanges are lose. It might be as simple as bad exhaust gaskets
Old 11-09-2011 | 07:59 PM
Could this problem give me bad gas mileage and bad idle?
yankie_1132
01-22-2013 12:39 PM
VI009DZ
01-17-2013 12:30 PM
reddem0n
01-15-2013 04:44 PM
OKhonda94
08-27-2010 04:33 PM
