Will not start until lock and unlock drivers door then runs?
I accidently switched off my car at DRIVE mode, then i switched to PARK mode. After few days I was unable to start my car early in the morning, there's no cranking sound but after i lock and unlock the door, i can start the car. I had been having the same problem every first time i start my car for the day. Could anyone can advise me what's wrong with my car? Your prompt advise will be much appreciated.
its a 2000 honda accord. all the while it was alright until the day when i left my gear in DRIVE and shut off the car.
now everyday the first time i start my car on the day, this will happen. but even after my work, it was alright too.
I have no idea where you can get a manual for the security system. That is an accessory item, so the testing procedure wouldn't be in the shop manual.
I would think that removing the negative battery cable for a few minutes should reset the alarm. Make sure to get your radio code before you do this.
Used to have a 1998 Accord automatic. I've switched off the engine when the trans is in "D" many times (I don't like automatics). Never had these kind of problems, so I'll go along with this being the alarm system.
HateThisHonda
09-19-2013 10:45 AM
Accord Pete
01-31-2010 03:50 PM
