window motors
Old 08-19-2008 | 05:36 PM
firefighter18170
Default window motors
Hi, i have a 97 accord se. my front driver and passenger windows roll down but will not roll back up. i am pretty sure my motors are bad. my rear windows are fine. i was wondering can i simpliy just switch my motors from the back into the front and put the bad ones in the back and replace them at a later time?
Old 08-19-2008 | 06:59 PM
hondadude's Avatar
Default RE: window motors
No, they are not swapable, the motor and regulator come as a complete unit.
Old 08-19-2008 | 09:45 PM
manu_b's Avatar
You can not interchange the regulators but you might be able to change the spindle of motors. thats what i did with my driver side motor. But are you sure motors are bad cuz when i opened them they dont have anything special they are just normal motors so if they turn one way they should go other way. try checking it by directly connecting it with battery if it goes one way then interchange the wire and see if it goes other way. The only problem ihad was taking out bushings because my motor was blown and plastic holding bushing was melted. Give ur self time repair them on weekend.
________
Michigan medical marijuana dispensary
charlieshore01
05-09-2011 09:07 PM
tommyp
02-02-2011 06:29 PM
DaIna-Kelela
10-04-2010 02:16 PM
gravey86
01-13-2007 03:03 AM
