windshield washer fluid light and code p420 and p 1457
Old 07-07-2007 | 08:35 PM
bougie_44's Avatar
Default windshield washer fluid light and code p420 and p 1457
also my windshield washer light is on the dash although the fluid is full.......and i got check engine codes p420 and p1457, one is about the catalytic and the other is about pressure in the gas tank or something, well I am going to get them checked out but in the meantime i was wondering if anyone had any idea about these codes... i have a 98 accord 2.3, 4d.... any help wpuld be appreciated... thanks
Old 10-15-2007 | 03:03 PM
bougie_44's Avatar
Default RE: windshield washer fluid light and code p420 and p 1457
For the p1467 i bought a used canister and a control purge valve used from the scrap yard for 100$ and changed it now the code is gone for a month, For the windshield washer light, i bought a windshield washer float sensor from the scrap yard for 10$ and that was fixed. for the p420 i changed the front oxygen sensor but the code is still there, i think it has to be my catalytic. I am going to try one of those pieces that you attach to the senor to trick the computer so that i can atleast clear that code for now....
Old 10-15-2007 | 03:13 PM
00AccordLX5spd's Avatar
Registered User
P420 is a CAT code. You can try the defouler trick as you mentioned. Or try to find a replacement cat at a scrap yard (if they will sell it to you)
Old 10-15-2007 | 05:14 PM
Glad you got the P1457 fixed. I must have missed your original post when it was new. (I was on vacation that week...)
P0420is based onthe REAR O2 sensor's measurement. That sensor's job is to measure whether the cat is working. The front sensor probably won't do anything to help your P0420.
Maybe it's possiblefor a bad rear O2 sensor to do this, but I've been told that by 1998 the ECU is quitegoodat telling the difference between a bad cat vs. a bad sensor.
Old 10-15-2007 | 05:19 PM
Registered User
Oh yeah...forgot to mention...do the defouler trick on the rear o2 sensor, not the sensor before the cat.
Old 10-16-2007 | 08:58 AM
ajluu's Avatar
Just changed the Rear Oxygen Sensor that's connected to the Cat for the P0420 Code. It worked for me.!
Old 10-16-2007 | 09:01 AM
ajluu's Avatar
36532-PAA-L02 is the part number
ChappyBob
10-27-2016 06:44 PM
crashdummie
11-23-2013 02:27 PM
larrypac99
01-14-2012 10:22 AM
"974thAccord"
05-20-2011 02:09 PM
zann121
06-22-2009 03:20 PM
