Windshield washer not working
It was working up until a few weeks ago. I filled it up to make sure that was not the problem but cannot get any fluid to come thru--not even a squirt. I have an 91 EX and the lines look ok.. What is some of the things I could check to get this working again. Thanks for your suggestions.
washer pump solution- it's not the pump!
if the pump runs but there's no spray, bypass the little bellows connector at the corner of the hood. Unplug the line from the straight connector at one end and plug it into the right angle connector that goes into the fender. That bellows kinks easy once old
crashdummie
11-23-2013 02:27 PM
bougie_44
10-16-2007 09:01 AM
