Windshield Wiper Chatter
Old 05-28-2007 | 07:48 PM
19962door's Avatar
Default Windshield Wiper Chatter
I've been having a problem with wiper chatter on the driver side.[:@]
I recently replaced both inexpensive wiper blades with expensive Bosch blades. For about two weeks, maybe one or two rain storms, it worked fine. Today, chatter started again on the driver side.
Should I replace the wiper arm? I don't think there's any problem with the motor, as the high speed setting works fine (slower than it should be though, because the wiper is "sticking" to the windshield on the left).
Thanks
Old 05-29-2007 | 05:48 PM
hondadude's Avatar
Default RE: Windshield Wiper Chatter
Not to be an *******; but as cheap as Honda wiper inserts areI have never understood why people change to the aftermarket blades.
The problem now is that you'll have to buy Honda blades to get back to square one and start all over again.
O.E.M. only hurts once
Old 05-30-2007 | 08:05 PM
19962door's Avatar
You think Honda blades will help? You mean the rubber wiper and the blade, or just the insert?
Thanks.
Old 05-30-2007 | 08:57 PM
Chiovnidca's Avatar
ORIGINAL: 19962door
Thanks.
I'd reccomend going back to Honda blades too. If you didn't throw your old ones out you can just put inserts on them.
Old 10-03-2007 | 02:05 PM
p5tom
Wipers in a nut shell - 2003 Accord EX 4 DR sedan ( 26 inch & 18 inch) - I have tried them all, wasting tons of cake - best setup is just doing refills and using the PIAA silcons ( refills) - little more than the oems but they last a hell longer and do a much better job.
Tom
Old 10-03-2007 | 02:26 PM
falkore24's Avatar
Is the chatter on the Bosch Icons? Ultrablades have this problem a lot. I had a pair of Valeos that sucked! Now I have Silblades and I like them a lot. They carry a 5 year warantee and I think have no competition in this category!
Old 10-03-2007 | 03:50 PM
2POINTautO's Avatar
Has anyone noticed a brand that is the newer nice silicone AND has Rain X (or something similar) built in for water beading, available in the USA. Very nice and pricey in Japan.
joj73
11-28-2012 06:19 PM
joj73
04-07-2012 03:49 PM
clutch811
06-24-2008 01:25 AM
importnewbie
08-10-2007 09:48 AM
Jirviss
04-29-2005 04:32 PM
